Activity Forums Adobe After Effects Particular Layer Emitter: transparent particles
  • Particular Layer Emitter: transparent particles
    Posted by Ralf Hekkenberg on October 18, 2011 at 5:29 pm
    Hi all, hope you can help me with this.
    Now I’m using Particular to dissolve a plant into particles in a very cartoony style. I’m using the same technique as in this tutorial: https://library.creativecow.net/articles/lee_james/particle_build_up.php (particles coming from a layer emitter)
    It’s looking pretty good but, about 10% of the particles is half transparent, even though all settings say that the particles should stay opaque.
    Could it be that, if Particular emits a particle from the edge of the shape on my layer emitter, it makes it half transparent? The layer I’m emitting from is a PSD with opaque and transparent parts.
    Shane Luskie replied 7 years, 6 months ago 6 Members · 7 Replies
  • 7 Replies
  • Stefan Hinze
    October 18, 2011 at 5:56 pm
    hey,
    check if the DOF is set to ON?
    looks like you have particles “out of focus”
    hope this helps
    Stefan
    OCCUPY!!
    we r 99%
    (well, i am… how about you?)
  • Ralf Hekkenberg
    October 19, 2011 at 10:53 am
    Hi Stefan,
    Thanks for thinking along but nope, I just checked and there’s not even a camera in the scene (I created one but this didn’t help either).
    Then I thought it must’ve been the visibility settings but those were all fine as well. Far Vanish and Fade settings are set at 100.000 and Near settings at 1 and 0.
    Any other thoughts?
  • Walter Soyka
    October 19, 2011 at 4:22 pm
    [Ralf Hekkenberg] “Could it be that, if Particular emits a particle from the edge of the shape on my layer emitter, it makes it half transparent? The layer I’m emitting from is a PSD with opaque and transparent parts.”
    That sounds plausible to me.
    Try precomping your PSD, and apply a Levels effect to the PSD layer within the precomp (not to the precomp itself in the main comp). Set Levels to Alpha (instead of the default RGB) and tweak the Alpha Gamma to get a harder edge.
    Walter Soyka
  • Ralf Hekkenberg
    October 19, 2011 at 4:43 pm
    Exactly the kind of fix I was looking for! I was just now trying to put a threshold on the particular layer’s alpha, and then choking that matte, but this had the side-effect of blending the particles together where they touch eachother.
    I tried your approach, and it doesn’t get rid of all the transparent particles, but it does bring it down to about 1-2%.
    Good enough for now.
  • Stef Prein
    November 29, 2013 at 2:50 pm
    I’ve had the same problem. After a search on Google, I found that a combination of Minimax and Mosaic should do the trick.
    So tried some things and came up with a combination of Minimax first, then Mosaic and then Levels (channel set to Alpha). You probably need to tweak the parameters to fit your layer emitter.
    Oh and apply the effects to the precomped layer, not the precomp itself!
    Stef Prein
    director/motion designer at StudioFets.
    Utrecht, The Netherlands
    https://www.studiofets.com
  • Jenni Pasanen
    September 26, 2018 at 8:17 am
    My solution for this problem was to make “Particle birth time” layer alpha and add “Matte choker” effect on it with 0% grayness. It will make the emitter composition pixelated, but there wont be any grey particles floating around. Hope this helps others in need.
  • Shane Luskie
    February 28, 2019 at 1:16 am
    Thanks, man, this really helped me, I was working on a disintegration effect with Trapcode Particular – I used this technique you offered and also tweaked up the Alpha Input White – thanks again.
