Activity Forums Adobe After Effects Particular- Keeping the same particles on
  • Particular- Keeping the same particles on
    Posted by William Saviola on November 24, 2015 at 8:46 pm
    I have a fish scene using particles as my fish using particular.
    I want my fish/particles to not be born and not die but the same particles to remain on the screen.
    How would i do that.
    At the moment i have the opacity and size over life giving the fish a scale and fade down but i just want an amount of fish particles to be in the scene through out. If i dont have this set the particles/fish will just appear on and off
    William Saviola replied 10 years, 9 months ago 3 Members · 4 Replies
  • Kalleheikki Kannisto
    November 24, 2015 at 9:22 pm
    You want to have all your particles already emitted when you enter the first frame.
    Two ways to accomplish this:
    1) Set the birth rate to the desired number per second for one second, then to zero after one second. Trim layer to start after one second, move back one second.
    2) Use the “Prerun” option to create the particles before the first frame
    Then you want the particle life to be at least as long as the layer/comp.
  • William Saviola
    November 25, 2015 at 9:48 am
    neither of those ways are working.
    the particles/fish still keep just coming on and off.
    I am using a box emitter and directional with all rotations set to 0
    my particle life is 12seconds for a 10 second comp
  • Walter Soyka
    November 25, 2015 at 11:09 am
    What version of Particular are you using? Older versions were susceptible to two issues that are both resolved (I think) in more recent builds.
    1) It’s possible that Particular is not properly invalidating the cache, so you end up recycling old frames instead of rendering new ones. Clear your cache.
    Ae CC/CC2014/CC2015:
    Edit > Purge > All Memory & Disk Cache
    Ae CS6:
    Preferences > Media & Disk Cache > Empty Disk Cache
    2) If your particles are popping on and off near the edges of your frame, this may be due to a problem with how Particular culled the frustum [link].
    Basically, I think Particular did not take the true size of a particle into account when figuring out if it should be rendered on-screen or not. Large particles that are near the edge may be erroneously removed from the scene because their center points have gone outside the boundaries of the solid — even though a significant amount of the particle is still on-screen. A workaround is to increase the size of the solid to which Particular is applied, so that the popping happens out of view of the comp.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • William Saviola
    November 25, 2015 at 2:59 pm
    yep this fixed it
    thanks Walter!
