Particular Help
Hi there,
I’m trying to achieve a certain effect with Particular and I’m hoping someone can help.
I’m trying to simulate water bubbles flowing through a valve. I want a stream of particles to start off with a vertical spread of, say 50 and flow horizontal from left to right. The particles then change their spread 1 second in, as the bubbles enter the valve, say to 20. Then as the bubbles exit the valve, the spread changes to 50 again. I’m using a light to define the motion path right now. Any suggestions?
Jay
