Activity Forums Adobe After Effects Particular help
  • Particular help
    Posted by Eran Solomon on October 4, 2006 at 10:51 am
    hey everyone,
    Im trying to achive a certian effect with particular and was wondering if anyone could tip/help me.
    I know this is going to sound a little weird but I am doing this as a project against smoking.
    I need to simulate a puking effect. yes, puking, with all sorts of weird colors and.. I’ll spare the description from you.
    Thanks in advance for all repliers.
    Aharon Rabinowitz replied 19 years, 11 months ago 3 Members · 4 Replies
  • Travis Turner
    October 4, 2006 at 3:28 pm
    maybe a more in-depth explanation would help in case particular isn’t the best tool to accomplish the look youre going for – but sounds like what you want to do is use a directional emitter with a medium wide directional spread – use custom particles for your multi-colored blobs – and make sure your gravity settings are appropriate so the particles fall soon after leaving the emitter – hope this helps
  • Eran Solomon
    October 4, 2006 at 4:45 pm
    Thanks a lot , I got somthing thats starting to look right.
    but I was wondering if theres a way to add more diffrent particles to the same emitter? I would like it to be varied and not just a brown object. (maybe add some greens , some watery like.).
    Is that possible?
    thanks in advance.
  • Travis Turner
    October 4, 2006 at 8:54 pm
    Yea – make your particle “customize fill” and then make “set color” set to “random from gradient” – at this point you can set the colors in the “color over life” palette to whichever you choose –
  • Aharon Rabinowitz
    October 4, 2006 at 10:12 pm
    FYI – We have a Trapcode Forum here where you may be able to get even more help.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
