Activity Forums Adobe After Effects Particular grid emitter stair-stepping
  • Particular grid emitter stair-stepping
    Posted by Matt Slocum on September 28, 2010 at 3:03 pm
    I’m trying to draw lines to swoop around (maybe 10 lines). I want them to be evenly spaced and kinda look like a ribbon. I changed the emitter to grid and the grid emitter particles in x,y,z to 1,10,1 and the type to Traverse. It seems to do what I want except that on fast motion it gives drastic stair-stepping. I tried changing the Position Subframe setting, but that isn’t working.
    I am new to particluar, in fact, I’m using the trial to see if it can do what I want before I buy it. Is this a trial limitation or am I doing something wrong?
    Matt
    AE 10.0.0.458
    Particluar 2.1.0
    John Cuevas replied 15 years, 12 months ago 2 Members · 8 Replies
  • 8 Replies
  • Matt Slocum
    September 28, 2010 at 3:46 pm
    Maybe, I was playing around with that a little. I might end up making a custom particle, but I wanted more controls of animating line proximity without scaling the custom particle. It seems like the grid emitter is exactly what I want, but it seems broken, or I’m doing something wrong. That is why I was also wondering if it had to do with my trial license.
  • Matt Slocum
    September 28, 2010 at 4:22 pm
    I tried increasing the Particles/sec up really high, but that doesn’t help. Increasing the frames per second on the comp helps some, but I guess I’m going to have to do the animation over a lot more frames and then speed it up to make the lines smooth. I thought I read that they fixed this with Particular 2?
  • John Cuevas
    September 28, 2010 at 4:46 pm
    Can you post a picture? I’m not entirely sure exactly what you are seeing.
    Johnny Cuevas, Editor
    http://www.thinkck.com
  • Matt Slocum
    September 28, 2010 at 4:53 pm
    The XYZ Positions, XYZ Rotation and XYZ Size are linked to a null that is animating over 20 frames. It is moving about 1000 pixels and rotating 180 degrees.
  • Matt Slocum
    September 28, 2010 at 4:55 pm
  • John Cuevas
    September 29, 2010 at 12:27 am
    Took me a bit to get back to this, been a busy day. So I messed around with this and it’s basically a math problem. You have the null rotating at 9 degrees every frame with a large velocity. Even from your picture, you can see that over 20 frames you get 20 lines, each 9 degrees apart. To get a smooth line you would have to adjust your frame rate 9 times faster to get a 1 degree move, or 180 frames per second but AE only goes up to 99 frames per second.
    To get the animation you want, you need to move your keyframes to 6 seconds(9 times the length it currently is). Precomp the entire thing and time remap.
  • Matt Slocum
    September 29, 2010 at 1:20 am
    Yeah John, I think you’re right. I was thinking that would be it, but I was hoping it would be a setting. I thought they claimed they fixed this with the new Position Subframe, but I guess it doesn’t work with grids.
    Thanks.
  • John Cuevas
    September 29, 2010 at 10:59 am
    Poking around, I found this thread from Norby: https://www.trapcode.com/forum/post/1031327
    Basically, there is no subframe accuracy for rotation.
    There is another work around, if you really need this to happen over 20 frames. Use lights. Create 10 lights in a straight vertical line. Parent them to your 3D null, change the emitter from grid to lights(s). Motion does have subframe accurracy. I did a quick test using the same parameters as before, (velocity, rotation) over 20 frames, but only needed 1500 particles to make the lines. Hope that helps you out.
