Activity Forums Adobe After Effects Particular Frequency
  • Particular Frequency
    Posted by Sascha1979 on April 12, 2007 at 9:37 am
    hi.
    can anybody help me?
    i am trying to make a particular which is changing the particle output fequently.
    for example a countdown wich is changing the numer every second?.
    thx for helping
    Sascha1979 replied 19 years, 5 months ago 2 Members · 5 Replies
  • Vinmark
    April 12, 2007 at 3:10 pm
    unless i am miss understanding you, it is very easy to key frame the partials per sec. just animate that and you are good to go.
    Vinmark Productions
    “leaving a mark on culture”
  • Sascha1979
    April 13, 2007 at 3:56 pm
    yes i can animate the particles… but if i animate them the particles which are allready out are also changing…
  • Sascha1979
    April 13, 2007 at 4:14 pm
    i tried Time Sampling: start at birth. ist nearly that what i wanted.
    but now only the dropped numbers are changing. the numbers near the emitter are always 10. i need an emitter like a countdown where evere second the output is changing.
    any idea?
    thx
  • Vinmark
    April 13, 2007 at 4:40 pm
    i would mess around with some hold key frames. this way you can frame 1 emitting 1000 particles frame 2 0 particles, then jump to 2 seconds and emit 2000 particles then a frame later 0 particles and so on. try this out if not please give me a better idea of what u are trying to do, hope this helps.
    Vinmark Productions
  • Sascha1979
    April 16, 2007 at 8:28 am
    ok i ll try it with more emitters and keyframe animation… thanx
