Activity Forums Adobe After Effects PARTICULAR FREEZE
  • PARTICULAR FREEZE
    Posted by Raphael Dias on July 20, 2007 at 4:52 pm
    Hello!
    I Need to obtain a effect SLOWMOTION in a animation where I create something similar to a WEB.
    That begin with a point small to become a great circunference, everything this from particles.
    I
    Raphael Dias replied 19 years, 2 months ago 2 Members · 2 Replies
  • Darby Edelen
    July 20, 2007 at 5:59 pm
    The Physics Time Factor (PTF) under Physics can freeze particles if you set keyframe it to 0, if you want the particles to suddenly freeze then you’ll want to use a hold keyframe of value 1.0 and then put a keyframe with a value of 0.0 when you want it to freeze. You might want to play with the Motion Blur settings when you do this, as you can set them to ignore the PTF, causing the particles to be motion blurred even though they’re not moving, or not.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Raphael Dias
    July 23, 2007 at 2:00 pm
    Thanks Darby!
