Activity Forums Adobe After Effects Particular Form – Curling a Layer Map’s Edge?
  • Particular Form – Curling a Layer Map’s Edge?
    Posted by Max Jackson on October 3, 2012 at 4:38 am
    Hi CC,
    I’ve been all over the map lately trying to figure out which direction I should go, so please excuse me if this post is redundant.
    I’ve got a shadowy ghost figure that I’m trying to create an shadowy ghostly aura that goes out from all sides. But I’m finding out that’s not possible with particular. At least, I can’t figure it out using a layer emitter. So I’ve resolved to just doing a form flow over the subject.
    I’m trying to do something subtle that curls up as it flows in a general direction.
    What control helps create that curl to the edge of the layer map? I seem to be able to twist and distort but nothing that really curls up.
    Is there a technique or method that helps curl up the edge of the map displacement flowing in a general direction?
    Thanks for reading. 🙂
    Max Jackson replied 13 years, 11 months ago 2 Members · 2 Replies
