Activity › Forums › Adobe After Effects › Particular for beam effect
  • Particular for beam effect
    Posted by Davor Kronja on November 24, 2015 at 9:24 pm
    Can I use particular plugin for AE to make a weapon beam?
    The origin of the beam and the target that beam is hitting are moving.
    I tried to make it with light as emitter, but it seems I do something wrong.
    Is there a way to make particles from place 1 go in the straight line to place 2 and when reach place 2 to dissolve?
    Any suggestion is welcomed… thanks
    Davor Kronja replied 10 years, 10 months ago 3 Members · 5 Replies
  • Mark Chatman
    November 24, 2015 at 10:05 pm
    I’d rather use Optical Flares by Video Copilot ,you can make alot of weird and creative stuff with it 🙂
  • Davor Kronja
    November 24, 2015 at 10:52 pm
    Possibly… But I would still like to know if I can make it with particular cause I need the particles to go from one point to the other. I don’t know how I can make particles with optical flares.
  • Davor Kronja
    November 25, 2015 at 12:24 am
    Thats a good idea. Thanks. Beam points can be animated. Is there a way to use beam effect as path for emitted particles?
  • Walter Soyka
    November 25, 2015 at 10:13 am
    [Davor Kronja] “Is there a way to make particles from place 1 go in the straight line to place 2 and when reach place 2 to dissolve?”
    Use Particular’s motion path [link] feature.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Davor Kronja
    November 26, 2015 at 5:36 pm
    Thanks for help… this technique is close to what I need… but still not exactly what I need…
    particles need to move in straight line from A to B and A and B are constantly changing position. Like, particles will make a line of particles between these two points, moving from A to B and dying when reach B.
    Anyway, thanks for advice… seems particular is not the best way to achieve this effect… kinda have to be done is some 3d program.
