Activity Forums Adobe After Effects particular ( falling rose ) in 3d space
  • particular ( falling rose ) in 3d space
    Posted by Omid Abesta on February 27, 2012 at 12:58 am
    hello
    I wanted to make Particle (particular) in order to i have falling CALYCLE ( like red rose)
    i made a 3d CALYCLE in after by effect:digieffects free form
    ( i wanted to use a 3d calycle photoshop but i did not find it)
    by useing particular and such setting as
    particle type: Sprite and its layer: my composition ( 3d calycle)
    because i wanted my particles fall around my character i had to set
    obscuration layer: my character’ layer (choromaki)
    now i want to help me
    1- did i go process true?
    2- i have a problem. 3d calycle layer, crosses my character’ layer
    3- can you introduce a tutorial about this
    3- can you get me (or introduce) a 3d calycle PSD or 3ds that i can import it to AE insteat of useing free form
    please see my clip to understand my project & problem better
    https://www.4shared.com/video/KoEtYQzB/3d_rose.html
    (i only placed a gray solid instead of my character. at first second 3d calycle crosses solid layer and then vanish)
    Chris Bobotis replied 14 years, 5 months ago 3 Members · 4 Replies
  • Omid Abesta
    February 27, 2012 at 1:56 pm
    i still have the problem
    my 3d particles crosses with obscuration layer and cause bad effect
    when my 3d particles is in behind it =>is ok
    when my 3d particles is in front of it => is ok
    but when they exactly crosses eachother in not ok
  • Andrew Somers
    February 28, 2012 at 9:21 am
    he obscuration layer is more of a convenience – but is not the best solution in all cases.
    In YOUR case, use TWO separate layers of Particular, one for front and one for back.
  • Omid Abesta
    February 29, 2012 at 9:45 am
    thank you
    good luck
  • Chris Bobotis
    March 31, 2012 at 4:32 am
    Nice use of FreeForm. Please show us the final clip when you are done
    Cheers,
    Chris
    mettle.com
