Activity Forums Adobe After Effects Particular, emitting random custom particle
  • Particular, emitting random custom particle
    Posted by Justin Porter on November 28, 2007 at 9:29 pm
    So I need to set up a particular emitter so it emits different words at random, however, I have no idea how I’d set it up so that each custom particle emitted is from a different source. Can anyone tell me how to do this?
    Gustavo Saliola replied 5 years, 6 months ago 3 Members · 2 Replies
  • Darby Edelen
    November 29, 2007 at 6:06 am
    [jporter313] “So I need to set up a particular emitter so it emits different words at random, however, I have no idea how I’d set it up so that each custom particle emitted is from a different source.”
    You can choose an emitter shape such as Box or Sphere and increase the size of the emitter. Your particles will be emitted randomly within those bounds.
    Alternatively, you can have multiple layers in your composition each with an instance of Particular applied.
    As I read your post again it looks like I may have misunderstood what you meant by ‘source.’
    If you want the emitter to choose a random word each time a particle is emitted you need to first create a pre-comp for your custom particle. Create your text layer in this pre-comp and animate it so that each frame in the pre-comp has a different word visible. Then set your Particular effect to use the pre-comp as a custom particle and under the Custom section choose “Random – Still Frame.”
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Gustavo Saliola
    February 7, 2021 at 6:16 am
    Thanks Darby! 14 years later, this one solved me a problem with a current mograph project. Needed to show a virtual space with “hundreds of far and tiny instagram profiles” which really only 12 exist. So made a small 9:16 precomp with (those) 12 frames and assigned as Sprite in Particular, with the Time option “Random – Still Frame.”
