Activity › Forums › Adobe After Effects › Particular: Emit Particles to specific Points
Posted by Ngo Truong an on May 8, 2017 at 9:36 pmHello Everyone, is it in Particular possible, to emit the Particles from a Logo to specific Points?
Ngo Truong an replied 9 years, 3 months ago 3 Members · 4 Replies -
Kevin Camp
May 9, 2017 at 4:43 pmnot exactly… but you may be able to manipulate motion paths to control the particles they move to a certain area…
here’s one tutorial on motion paths, but there are others: https://vimeo.com/17376842
Foam allows control of the motion of particles using a grayscale map. so you might be able to manipulate that effect to get what you want… here’s a really old tutorial on using ‘flow maps’ in foam: https://www.creativemac.com/2004/02_feb/tutorials/positiveluv.htm
it’s not a 3d particle system, so it may not work for what you need….
Kevin Camp
Art Director
KCPQ, KZJO & KRCW -
Steven Perry
May 9, 2017 at 6:27 pmI think if you combine layers… you could trick the effect
1. A particle layer that emits particles from logo to a cloud
2. A particle layer that emits particles from points to same cloud.
3. Pre-comp and time reverse the layer in step 2.Looking up how to make a perfect particle loop may help to understand the concept.
https://youtu.be/V55hA573yRY?t=21m1sSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Ngo Truong an
May 23, 2017 at 7:03 pmSorry for the late reply Kevin, it was so stressful at work, thank you for your Advice. Greetings An
Ngo Truong an
May 23, 2017 at 7:11 pmHi Steven, sorry for my late reply, it was so stressful at work, this is really helpfull. I think this could work.
I will try this out, when it will be less stressfull.
Thanks and greetings An.
