Activity Forums Adobe After Effects Particular – depth of field
  • Particular – depth of field
    Posted by Ian Collister on June 10, 2009 at 12:53 pm
    Im trying to get depth of field with particular, but not getting any results. Does it not except the camera setting as its on a 2d layer? Is there anything within the particular settings i can use to achieve the usual depth of field look i get from my AE cameras?
    Cheers
    Ian
    Ian Collister replied 17 years, 2 months ago 2 Members · 2 Replies
  • Darby Edelen
    June 10, 2009 at 4:28 pm
    For particular to render the depth of field effect you need to have the Render Mode set to Full Render + DOF Square/Smooth and you need a camera with Depth of Field ‘On.’ Once you’ve set the Render Mode in the effect (it’s at the very bottom) it should obey all the camera settings.
    Darby Edelen
  • Ian Collister
    June 10, 2009 at 7:02 pm
    Nice one Darby, much appreciated!!!
