Activity › Forums › Adobe After Effects › Particular box emitter affected from two sides
  • Particular box emitter affected from two sides
    Posted by Philipp Omba on June 2, 2020 at 7:02 pm
    Hi! I‘ve got a scene in a Film, where you can see a forest scene with a huge stone in the middle of the picture. Beginning from this stone, there should be particles flying in the air to a hologram of a planet. I‘m using Particular and a box shaped emitter. The particles should emit from the whole shape of the stone, but the particle flow should be quite narrow when ending in the hologram of the planet. I‘ m looking for a way to affect a particle from both sides, so that there is a huge area where the Particles emit and a the stream of the particles is quite narrow at the end. Does anyone know the solution? I added a picture to describe it better.
    14169_80f327e378d546d6ae26a2282e7d99ff.jpeg.zip
    Graham Quince replied 6 years, 3 months ago 2 Members · 1 Reply
