Activity Forums Adobe After Effects particular and making a crowd
  • particular and making a crowd
    Posted by Mike Lister on February 29, 2008 at 8:29 pm
    hi all,
    i’m trying to make a crowd using particular.
    i’ve got particular using a 200×200 comp of people silouettes.
    it’s all set up, however when i rotate my camera, the crowd rotates as if auto-orient is turned on. I can’t figure out how to rotate the camera and NOT have the crowd rotate with it.
    is this possible?
    Louis Jaime replied 18 years, 6 months ago 4 Members · 4 Replies
  • Lloyd Alvarez
    February 29, 2008 at 8:38 pm
    Harry Frank did a tutorial on how to accomplish this. You can see it on his website:
    https://www.graymachine.com/content/index.php?option=com_content&task=view&id=22&Itemid=31
    https://aescripts.com
  • Mike Lister
    February 29, 2008 at 8:59 pm
    Dave, thanks for your reply.
    What switch are you speaking of?
    even if i parent the camera to a 3D Null the people rotate with the Null…
  • Darby Edelen
    February 29, 2008 at 10:25 pm
    Particular always orients particles to face the active camera, if it didn’t then most particle systems it generated would look very fake when orbiting (i.e. postcards in space).
    The way around this is an odd sort of workaround. You’ll need to go into your ‘people pre-comp’ and make your ‘people layer’ a 3D layer, then go back into your main composition and enable collapse transformations on the pre-comp. You’ll also probably need to increase your particle size in particular. With the transformations collapsed Particular will not automatically orient the particles, but will instead mirror whatever orientation the pre-comp has relative to the camera.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Louis Jaime
    March 8, 2008 at 6:36 am
    Thanks! It worked perfect!
