Activity Forums Adobe After Effects Particular Anaglyph
  • Particular Anaglyph
    Posted by Frank Ruggiero on August 7, 2013 at 9:11 pm
    Hi Experts.
    Does anyone have any experience of working with a Particular particle system in stereoscopic 3D? Does After Effects treat each particle in real 3d space, so that it appears that way when viewing with the Red Blue Anaglyph glasses?
    One issue that I am having is that my particle system seems to be displaying blue on the left and red on the right.
    All the rest of my objects are red on the left.
    Is there a way to adjust this in particular without making the layer a 3D layer?
    Thanks in advance.
    Frank
    Alexander Cama replied 13 years ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    August 7, 2013 at 9:22 pm
    Go ahead and make it a 3D layer. There’s too much BS about not making layers with 3rd party 3D plugins 3D layers. The only time you shouldn’t do this is if it interferes with AE’s 3D interactions and the results are not to your liking. IOW, just do it and see if things mess up. Oftentimes, you can get away with it.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
  • Alexander Cama
    August 7, 2013 at 11:56 pm
    If you make the particular solid a 3d layer, the particles will not appear in the anaglyph 3d space separately, they will appear flat at the position of the 3d solid’s layer that you applied particular to. The solid is now in the anaglyph space. Ask josh.
