Activity Forums Adobe After Effects particular
  • particular
    Posted by Gon Perdigao on December 3, 2008 at 12:33 am
    Hi there i want that particle build an image and then unbuild the sam image, but with different settings, i found this tutorial that teachs how to build an image, but the solution that James Lee give to build an image is to make a time remap. I saw a tutorial with lettring that particular build and unbild some text, but i can’t find that tutorial on line, can anyone help me please?
    Mike Park replied 17 years, 9 months ago 2 Members · 1 Reply
  • Mike Park
    December 3, 2008 at 3:48 pm
    The only way I know of to do this effect is to use 2 layers of the same text. Use particular to do the effects in the different ways you want and then time remap the first layer to create the build. This way, the layer will build to the text, which will map perfectly to the second text layer, which will then dissolve. There is no way with particular to build up text without time remapping, unless you simply want the particles to appear static on the text.
    Best of luck
