Activity › Forums › Adobe After Effects › Particular 2 – Textured polygon rotation problems
  • Particular 2 – Textured polygon rotation problems
    Posted by Andrew Downie on March 1, 2013 at 12:07 pm
    I’m using Trapcode Particular to create a moving/twisting wave using the textured polygon option. I’ve tried higher particle numbers, different position subframes, and smoother beziers but I can’t seem to stop getting a pixelated broken stream look when I rotate the particle.
    Does anyone know a method of smoothing this out, or if I’m doing something wrong?
    Image attached
    Andrew Downie replied 13 years, 6 months ago 2 Members · 4 Replies
