Activity Forums Adobe After Effects Particular 2 Problem with Custom Particles and Orient to Motion
  • Particular 2 Problem with Custom Particles and Orient to Motion
    Posted by Dino Muhic on December 3, 2009 at 11:24 am
    You see, this is my problem. When using Particular to emit a custom particle along a motion path it works ok until you look at the object exactly from the side. Then the custom particle (which is obviously flat) becomes so thin that it’s not visible anymore. It breaks the object.
    The effect is always there and reproducable. Changing the particle amount doesnt help. Does anyone have an idea how to solve this? I know Particular very well but this bugs me already for weeks. I want to form 3D objects with this method but this “bug” makes it impossible to look at it from most positioins…
    I mean I understand WHY it happens, it’s not really a bug, but it should be possible somehow to make a workaround for this.
    Thank you
    Dino Muhic – Media Producer
    VFX – Motion Graphics – Web-Design – Or just ART
    http://www.dinomuhic.com
    Dino Muhic replied 16 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
