Activity Forums Boris FX Particle Illusion ParticleViewr not finding my main Illusion Libraries
  • ParticleViewr not finding my main Illusion Libraries
    Posted by Matt Grunau on July 17, 2008 at 5:39 pm
    Hi all. I just installed Particle View and ran it for the first time. It did not launch Building Search Index File, it opened straight up. When I tried a search, it only searched the default file which came with Particle View. It is not finding my main Particle Illusion libraries which are located here:
    C:\Program Files\particleIllusion_3\Emitter Libraries
    I also tried to manually change the search directory by clicking edit in the Search portion, and when I put in the above location in, saved and restarted PV and tried a search, I got a runtime error and PV shut down.
    I can’t understand what I am doing wrong. I watched Alan’s video (I put a post on the youtube page, sorry Alan for the double post, I forgot about the Cow forum) and when he did a search everything from all libraries was diaplayed. I can load single libraries from Illusion fine, and when I do a search it will only search the library I loaded. Very odd.
    Any help would be appreciated.
    Thanks guys.
    Matt
    Matt Grunau replied 18 years, 1 month ago 2 Members · 4 Replies
  • John Holste
    July 17, 2008 at 6:43 pm
    Matt,
    Try the “add” button to add a new path to the search. Using the “edit” button is a bit picky about the syntax of the path.
    John
  • Matt Grunau
    July 17, 2008 at 7:42 pm
    Add will not allow me to choose a directory, just a library. And now, I am getting a Runtime Error and shutdown every time I try and search.
    I’m going to do a quick reg clean and try again.
    Should I be installing this inside the main Illusion directory? If so, why does it create its own folder?
    If not, I have no idea what I am doing wrong.
    THanks for the help John.
  • John Holste
    July 17, 2008 at 8:37 pm
    Matt,
    Yes “add” does make you choose a file but it uses the path to the file as a path to search for Emitter Libraries.
    particleView(pView) doesn’t use any registry so that likely won’t help but to make sure you have a clean install delete these files before reinstalling.
    \All Users\Application Data\wondertouch\particleView\
    pView_prefs.dat
    \All Users\Application Data\wondertouch\search data\
    Image.pIs
    Index.pIs
    IndexSum.pIs
    KeyWords.pIs
    Paths.pIs
    If you are a particleIllusion 3.0 owner pView should go in your particleIllusion folder in Program Files, pView will automatically look in the “Emitter Libraries” folder.
    John
  • Matt Grunau
    July 17, 2008 at 10:34 pm
    That did it. It didn’t automatically start off and build the index, it loaded the 1 inside PV. I did the “Add”, restarted, and it told me there had been a change do I want to update? I updated and it built the thing properly.
    Thanks for all of your help.
    Help like this is one of the reasons I keep telling people to buy this software. So many folks out there don’t take it as a serious app, and my 3D buddies and visual effects guru friends are constantly amazed when I put something together, and tell them I used it.
