Activity Forums Boris FX Particle Illusion particleView example doesn’t animate
  • particleView example doesn’t animate
    Posted by Leigh Young on August 7, 2012 at 7:10 pm
    The particle in the viewing window doesn’t animate. It’s like it’s on pause, which it’s not, and it won’t change when I scroll through search results. Not sure how to fix this.
    Alan Lorence replied 14 years, 1 month ago 2 Members · 8 Replies
  • 8 Replies
  • Alan Lorence
    August 7, 2012 at 7:30 pm
    Probably an OpenGL issue. Have you updated video drivers lately? Perhaps you should. (and you’re certain it’s not paused?)
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • Leigh Young
    August 7, 2012 at 7:59 pm
    I’m certain it wasn’t paused. The strange this after restarting it a dozen times it started working again.
  • Leigh Young
    August 9, 2012 at 2:46 pm
    I’m not being prompted to update any video drivers.
    I have to restart my computer for the search window to animate again. I’ll use it, go onto something else and when I come back to it again, it’s stopped working. The same goes for particleIllusion itself. It will work, I’ll use it, work on something else, and when I come back to it nothing will animated when I press Play. The window is stuck on whatever was there last. The only thing that fixes it is a restart of my computer.
  • Alan Lorence
    August 9, 2012 at 3:05 pm
    You won’t get a prompt to update video drivers. Do you know if you have graphics hardware based on NVIDIA or AMD/ATI? Whichever it is, go directly to the NVIDIA or AMD websites and download the latest driver installers.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
  • Leigh Young
    August 9, 2012 at 4:49 pm
    I’m using a Mac with OS 10.6.8. If a driver needed to be updated, it would be included in an update for the OS. I’m all up to date as far as that’s concerned so I can’t figure out what’s happening. It’s random when it works and doesn’t so it’s hard to duplicate what’s going on when it happens.
  • Alan Lorence
    August 9, 2012 at 4:53 pm
    Ah, right, on Mac it’s a different story.
    You’ve hit the spacebar to pause/unpause, and that’s definitely not the problem, right? Make sure you click in the preview window before hitting spacebar.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
  • Leigh Young
    August 9, 2012 at 5:09 pm
    Pause is definitely not a problem. Something else that’s happening is I’ll start up particleIllusion and everything in the windows will be white until I cover up part of the screen with another app’s window, then everything under that window now appears but still won’t animated or move. Hard to describe, hope that makes sense.
  • Alan Lorence
    August 9, 2012 at 5:33 pm
    Next time it happens, try resizing the preview window and see if it starts animating again, or switch into full-screen mode and then back.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
