Activity › Forums › Maxon Cinema 4D › particles to clean streaks/lines
  • particles to clean streaks/lines
    Posted by Ronny Traufeller on June 19, 2014 at 2:00 pm
    hey people,
    i am emitting particles from a moving emitter,
    so it looks sort of a line, consisting of dots.
    maybe there is another way to create lines
    out of particles, because i need increase the amount
    of particles to a huge number to have nearly clean lines.
    ps:
    i used also the tracer technique.
    but that way it is creating a line starting from each
    particle. not chaining all together.
    thx,
    Ronny!
    traufeller.de
    Brian Jones replied 12 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Adam Trachtenberg
    June 19, 2014 at 3:30 pm
    Set the tracer object’s tracing mode to “connect all objects”.
  • Ronny Traufeller
    June 19, 2014 at 4:04 pm
    traufeller.de
  • Ronny Traufeller
    June 19, 2014 at 4:45 pm
    it gives me sort of an crazy result,
    because its emitting from vertices of an object
    it is connecting the first stack of points and
    then so on.
    before
    after
    i was thinking to tell the tracer to just connect every 24th particle (because its emitting 24 every frame), so it is connecting the right ones in a chain. but puuhh, no idea to make such precise calls
    to the tracer ..
    i guess i need to stick to small sphere again to keep the streaks.
    is there maybe a little trick to keep the particles low ( maybe use stick shape )
    Ronny
    traufeller.de
  • Brian Jones
    June 19, 2014 at 4:53 pm
    are you using only one emitter or do you have one emitter for each ‘line’ of dots?
  • Adam Trachtenberg
    June 19, 2014 at 6:34 pm
    Since you’re connecting the particles and the tracer spline will represent the stream, you need to cut the particle count WAY down.
    Are you using a standard emitter or thinking particles?
  • Ronny Traufeller
    June 20, 2014 at 10:54 am
    i am using TP,
    a plane emitting particles on
    its vertex points (24 particles each frame).
    having an emitter for each streamline + tracer
    is possible, but quite messy.
    thx
    RRR
    traufeller.de
  • Adam Trachtenberg
    June 20, 2014 at 2:57 pm
    What you want to do is emit the particles on the first frame only (24 particles total) and then trace those particles.
  • Brian Jones
    June 20, 2014 at 3:08 pm
    or trace the vertices of the plane
