Activity Forums Maxon Cinema 4D Particles rotate from an emitter under a cloner?
  • Particles rotate from an emitter under a cloner?
    Posted by Brian Murphy on April 28, 2011 at 9:49 pm
    Hi all,
    If I have an emitter under a cloner and have particles emitting, I want those particles to tumble in the air, like confetti falling. I can get them to fall and land on the floor, but they fall without rotating. Any way to do this? I know I can rotate the particles but they rotate AFTER they land if I do that. I need to rotate within the dynamics system.
    I read about using an effector but I can’t make it work.
    Any help?
    Thanks a lot!
    Brian
    Adam Trachtenberg replied 15 years, 4 months ago 3 Members · 2 Replies
  • Jack Cook
    April 29, 2011 at 11:49 am
    Have you tried the rotation settings in the emitter itself? I’ve never put an emitter into a cloner, but I should think that would still work.
    Jack
  • Adam Trachtenberg
    April 29, 2011 at 2:54 pm
    Assuming that you’re using dynamics or modynamics, assign a custom initial rotation in the rigid body tag.
