Activity Forums Video Copilot Particles orbiting in 3D
  • Particles orbiting in 3D
    Posted by Pouyan Fard on April 23, 2008 at 3:36 pm
    Hello and thanks in advance
    I have made an orbit path (in Z space) for my particular imitter (using video copilot preset). I want to place a picture in the middle of the orbit so the particles would circle around it. BUT when I do so when the emitter gets behind the picture is still visible.
    I am using Trapcode Particulare.
    Any advice would be trully appriciated
    thanks
    Darby Edelen replied 18 years, 4 months ago 2 Members · 1 Reply
  • Darby Edelen
    April 23, 2008 at 3:45 pm
    Particular has a feature in the ‘Visibility’ section called ‘Obscuration Layer.’ You must assign this property to the 3D layer you want to be in the center of the particles. This needs to happen because Particular is being calculated in 3D space, but resides on a 2D layer (think of it as a fancy floating flatscreen TV that happens to be able to represent things in 3D… on a 2D plane).
    For this to work you will also need the layer to which Particular is assigned to reside above the ‘obscuration layer.’
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
