Activity Forums Adobe After Effects Particles not rendering correctly
  • Particles not rendering correctly
    Posted by John Knapich on February 11, 2009 at 8:15 pm
    I am doing an animation using Sure Target to go between several logos which are pre-comped and 3D.
    i have a CC particle world layer (explosive, faded sphere) sitting on top.
    the problem is in the first 2 secs of animation. the particles fade up with lots of blinking and erratic movement. Once they are up they work fine, fluid motion etc.
    is this a rendering problem? here are my settings, maybe someone can help me troubleshoot thanks.
    Jens Enqvist replied 17 years, 7 months ago 2 Members · 2 Replies
  • John Knapich
    February 11, 2009 at 8:25 pm
    correction
    seems my camera is jumping around the first 2 secs. I have a wiggle(.15,150) in the expression position but this should not cause that. I will look in the graph
  • Jens Enqvist
    February 12, 2009 at 8:06 am
    Did you check your Opacity Map (in Options)?
