Activity › Forums › Adobe After Effects › Particles in synthesia
Posted by Alexander Nilsson on November 8, 2018 at 3:24 pmI’ve been trying to achieve this effect :
https://www.youtube.com/watch?v=aeEmGvm7kDkI’ve got my synthesia file, but i can’t seem to figure out how to do it. The youtube creator said himself that it was made with AE. I’m still really fresh in After effects, so I could need some step by step guidance, like for dummies… ☺
Thanks in advance!
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Gould Lin replied 7 years, 10 months ago 4 Members · 9 Replies -
Cassius Marques
November 8, 2018 at 5:54 pmIts not the first time this has come up here. Check this thread: https://forums.creativecow.net/docs/forums/post.php?forumid=2&postid=1132533&univpostid=1132533&pview=t
Kalleheikki Kannisto even supplied project files explaining the quickiest ways to accomplish that.
Cassius Marques
http://www.zapfilmes.com -
Alexander Nilsson
November 10, 2018 at 1:51 pmHi! Thank you for redirecting me! However, I’m really fresh to after effects, and I can’t seem to get it to work with his project files ( even though he’s probably very thorough).
Now I’ve added a video to my main comp. I’ve duplicated that one and added keylight to it, made the green notes/bars transparent, added a solid layer underneath and made my bars blue. I’ve then added a spotlight emitter, which the particular and optical flare is linked to.
What I’m trying to do is, when the blue bars hit the piano roll, particular and flare will generate/start, then as soon as the piano roll doesn’t have any blue bars within its area, it should stop generating/stop the effect.
Is that possible without having to script? Sorry if I’m being too much of a novice here… ☺ I’ll add a picture of my process!
November 10, 2018 at 7:13 pmThat other solution was without expressions. If you’re going to use lights as emitters, you will need an expression for the light intensity.
Here’s an expression that checks whether the color underneath the light location on a layer named “keyboard” matches a specific color and turns the light intensity to 100 if it is a match, otherwise the light is at 0. The match is being checked against the blue color of the piano roll in the sample image you provided.
Rename your synthesia footage as “keyboard” or change the layer name in the expression to match yours.Add this expression to the Light Intensity property:
L = thisLayer;
pos2d = L.toComp([0,0]);
T = thisComp.layer("keyboard");
Tcolor = T.sampleImage([pos2d[0],pos2d[1]], [0.5,0.5], true, time);
colorR = Math.round(Tcolor[0]*255);
colorG = Math.round(Tcolor[1]*255);
colorB = Math.round(Tcolor[2]*255);
lightOn = false;
tolerance = 3;
matchR = 5;
matchG = 120;
matchB = 200;
if (Math.abs(colorR-matchR)If you need to check for a match to a different color (like a darker blue or green), you'll need to adjust the RGB values (matchR, matchG and matchB).
If you need to check matches to multiple different colors for a single light, you'll need to duplicate the three match lines and the if line and change the RGB values for each color that you want to match.
This way you can use the light as an emitter for Particular, for Optical Flares and as a light source. The down side of this method is that you need to make as many lights as you have keys. So once you have a single light that works as expected, you will need to make a whole bunch of copies to place one at the top of each key.
Senior Graphic Designer -
November 10, 2018 at 7:39 pmThe setting of sampling a single pixel ([0.5, 0.5] on the sampleImage line) is susceptible to flickering, you may want to increase the values.
Alexander Nilsson
November 10, 2018 at 9:21 pmHi! Thank you for taking your time and answering!
I used your script, but it doesn’t trigger all the time, I’ll provide a picture. I’ve also put out a few more emitters, though only some of them triggers.
As you said, it will take some work to place out all of the emitters. Wouldn’t it be possible to make a mask and then, when the blue bars hit the mask, particular and optical flares will generate/start, and end as soon as there is no more blue bars?
November 10, 2018 at 10:55 pmThere’s no such trigger event as “color hits mask”. There are layer emitters, which are used in the first example (meaning the one in the earlier, linked thread) and light emitters that are used in the one described here.
A couple of things of note:
The keys and the piano roll are not aligned in your screenshot. Neither are the lights and the keys, at least not that accurately. There seems to be a lighting effect already in place in the original footage when the keys are played. All thse things throw off the triggering.Kalleheikki Kannisto
Alexander Nilsson
November 12, 2018 at 3:13 pmIt works now, finally! Now I just have to configure the particles to behave the way I want them to. Thank you very much for your expertise! ☺
November 12, 2018 at 8:11 pmAwesome! Post a sample here of your final look if you get the chance.
Gould Lin
November 21, 2018 at 1:14 amKalleheikki Kannisto:
Can you please make a dummy file with optical flares as a trigger?
My idea is that when the synthesia bar falls into the piano, the top of the key will illuminate, and it’s determine the time to trigger the particle(use particular and set emitter type with light?) by the light length of the brightness. Is this possible?
