Activity Forums Adobe After Effects Particles from a path?
  • Particles from a path?
    Posted by David Fleury on September 26, 2007 at 6:48 pm
    I’m trying to find a way to emit particles from a stroke / path. I’m using trapcode particular. I’m not having a lot of luck. Is this possible?
    And in a similar vein what is the best way to generate fire?
    Basically I am trying to simulate a burning oil well.
    Thanks in advance
    David Fleury replied 18 years, 11 months ago 3 Members · 4 Replies
  • David Fleury
    September 26, 2007 at 6:52 pm
    Actually forget the fire part – I just found a preset that I can mess with.
  • Omnidecay
    September 26, 2007 at 6:57 pm
    I know of an expression you can use to help. If you alt+click on the XY position in particular, pick whip down to the position of the stroke. Hit enter after and now Particular will emit particles from the stroke position. I hope this helps.
  • Harry Frank
    September 26, 2007 at 7:29 pm
    For a particle path…
    1. Create a Point Light called “Motion Path 1”
    2. Align your Particular emiter XY to the Light XY
    3. Animate the light
    4. In Particular go to Physics>Air>Motion Path.. and select “1”.
    You should now see your particles moving along the path of the light.
    Harry J Frank
    Freelance Motion Designer
    graymachine.com
  • David Fleury
    September 27, 2007 at 4:02 am
    Im actually looking to make the path “The” Emitter. I think I may be able to simply make a very thin mask and using a Layer Emitter
