Activity Forums Adobe After Effects Particles Don’t Appear when Solid is 3d
  • Particles Don’t Appear when Solid is 3d
    Posted by David Bark on January 28, 2011 at 8:14 pm
    Following along with the Particular documentation. Created a spot light called “Emitter” and a black solid.
    Light is red. when solid is 3d, I can see the particles only when light is oriented towards me. When solid is 2d, I can see the particles at all orientations, but they no longer take on the color of the light. I don’t understand.
    David Bark
    Lightshine Productions
    Tudor “ted” jelescu replied 15 years, 7 months ago 4 Members · 4 Replies
  • Michael Szalapski
    January 28, 2011 at 8:22 pm
    Wait. Are you saying you made your Particular layer 3d? Don’t do that. Particular (and ANY effect that renders a pseudo-3d image) needs the layer to be comp-sized and 2d.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Olin Padilla
    Check you comp from a different view where you can see the depth. Your light is probably not where you think it is.
  • David Bark
    January 29, 2011 at 12:31 am
    Thanks, guys!
    David Bark
  • Tudor “ted” jelescu
    January 29, 2011 at 9:38 am
    the 2d Particular layer should be on top of all 3d layers if you want it to interact with all 3d layers in 3d space.
    Tudor “Ted” Jelescu
    Senior VFX Artist
