Activity › Forums › Adobe After Effects Expressions › Particles animation
  • Particles animation
    Posted by Andreas Zeiner on September 18, 2008 at 8:07 pm
    hello everybody
    i’m currently doing some complex particle animation and tried out a lot of things for this kind e.g. foam, particle world, particle playground and so on.
    the problem is the following –
    * i have a constant number of particles wobbling around (2D side view)
    * then they have to float through a narrow hole (an outer cell structure) into the inner part of the cell
    * there a few other particles are spawning and spreading through the cell
    * then a few particles are influxing into the inner cell and back to the outer cell structure.
    * during the whole process of movement the particels should follow a “leader” but more approximative than linear … hope you know what i mean – and still wiggling …
    as you can see this should be a very controlled process –
    with a bunch of manual animated particles this could be accomplished of course but the change management in terms of speed or movement would be horrible.
    maybe someone can give me a hint concerning how to accomplish this task- either with expressions or something like that.
    thank you very much
    andy
    Andreas Zeiner replied 18 years ago 1 Member · 0 Replies
  • 0 Replies
