Activity Forums Adobe After Effects Particles
  • Posted by Egil Arntzen on March 16, 2016 at 10:17 am
    Hi guys I am making some particles, and it is looking like this at the moment:
    But the appear too flat to me. I want them to have some texture and more shading on each individual particle. My effects so far are: CC Particle World, gradient ramp, glow
    I am using AE cc 2015, MacOsx.
    Viktor Svetin replied 10 years, 6 months ago 4 Members · 6 Replies
  • Kuljeet Singh
    March 16, 2016 at 11:55 am
    hi….
    if you want more control over the particles like shading, ambiet, diffuse, even reflection map etc.
    I would recommend then to use “Trapcode Particluar” rather than CC particle world system, as trapcode particular have more precise control over the particles, emitter, physics stc.
    hope it helps.
  • Kuljeet Singh
    March 16, 2016 at 12:04 pm
    if you want to continue with CC particles, than you can use “Shaded Sphere” in particle drop dwon option to add reflection to the particles. light direction option is also available in extras to work further with the light directions.
  • Egil Arntzen
    March 16, 2016 at 12:09 pm
    Thanks for the tip! Trapcode costs $400, right? Is it any way to do this with the free plugins? At least improve it? I know Trapcode will be a lot better, but I am on a tight budget…
    Cheers.
  • Egil Arntzen
    March 16, 2016 at 12:58 pm
    Are the reflections added to the particles by just choosing Shaded Sphere? Cause nothing is happening when I tweak on the light directions under “extras”…?
  • Kevin Camp
    March 16, 2016 at 6:48 pm
    if you choose any of the ‘lens’ particle types cc caprice world will use the layer it’s applied to as a texture map. you’d want to either apply the effect to an image or piece of video rather than a solid, or you could add an effect that generates a texture (like checker board or fractal noise) and then apply particle world to see how the ‘lens’ particles work.
    another option could be to use any of the ‘textured’ particle types, which allow you to select a different layer as a texture to use for the particles. I’ve done this to create glittery particles…
    first create a comp to use as a texture. it shouldn’t need to be too large, maybe 100×100.
    add a new solid, add fractal noise and animate the evolutions to rapidly change from frame to frame and increase the contrast. if you want to color it, try adding tint, tritone or colorama, or you could colorize in the main comp if you’d rather, that way you can see how the system looks over your background.
    bring that comp into the comp with particle world, select one of the ‘textured’ particle types, select the 100×100 comp as your texture layer in the particle settings and sett the texture time to birth. also, setting the color map to ‘origin constant’ will make the particles take on the color of the texture layer, rather than blending it with the color map colors.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Viktor Svetin
    March 24, 2016 at 8:52 pm
    There is program for creating special effects Magic Particles. It costs 90$ for 2D version or 180$ for 3d version and it has a free plugin for After Effect
    https://astralax.com/articles/ae
    Maybe, such program will be better for you.
