Activity Forums Adobe After Effects Expressions particle world position link to null
  • particle world position link to null
    Posted by Jonas Espinoza on July 24, 2008 at 6:23 pm
    having trouble linking the individual position x, y, z values with the position values from a 3D enabled null
    the particle world emitter still works until i move the null in any direction and it just disappears
    [url=https://img185.imageshack.us/my.php?image=picture3oe6.png][img=https://img185.imageshack.us/img185/3505/picture3oe6.th.png][/url]
    Ido Shor replied 9 years, 9 months ago 3 Members · 5 Replies
  • Jonas Espinoza
    July 24, 2008 at 6:50 pm
    dang, that link didnt work, lets try this one
    [URL=https://img185.imageshack.us/my.php?image=picture3oe6.png][IMG]https://img185.imageshack.us/img185/3505/picture3oe6.th.png[/IMG][/URL]
  • Dan Ebberts
    July 24, 2008 at 9:18 pm
    This should work for x:
    p = thisComp.layer(“Null 1”).transform.position;
    d = (p – [thisComp.width/2,thisComp.height/2,0])/thisComp.width;
    d[0]
    Then just change the last line to d[1] for y and d[2] for z.
    You’ll probably need to fiddle with the effect’s camera paramters to get it to match up exactly.
    Dan
  • Jonas Espinoza
    July 24, 2008 at 9:27 pm
    thanks – does particle world use some kind of wierd comp size coordinate units?
  • Dan Ebberts
    July 24, 2008 at 9:32 pm
    It appears that 1.0 in Particle World equates to the width of the comp, with the center of the default view being [0,0,0].
    Dan
  • Ido Shor
    November 29, 2016 at 9:02 am
    I know it’s an old thread, but still relevant.
    it seems the X code you wrote works fine, but the Y doesn’t for some reason.
    I changed the d[1] as you said, I also changed the first line to match the y.Position also.
    no luck, any idea?
