Activity Forums Adobe After Effects Particle world only plays particle animation once
  • Particle world only plays particle animation once
    Posted by Paul Wright on October 19, 2010 at 7:43 am
    Hi there,
    I have been using particle illusion and while it is great for quick little particle flourishes, I want to get to grips with particle world in after effects. I have used it for things like ash and rain and such, but one thing I was trying was a 3d shower of poker chips. Particle world only plays the spinning chip animation from lightwave once.
    Is there a way to change this?
    Many thanks in advance.
    Paul
    Paul Wright replied 15 years, 11 months ago 2 Members · 2 Replies
  • Kevin Camp
    October 19, 2010 at 3:30 pm
    with particle world you’ll need to loop the animated chip.
    an easy way to do that is to select the chip footage in the project window/panel and choose file>interpret footage>main. then set the number of times you want it to loop at the bottom of that window.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Paul Wright
    October 22, 2010 at 7:31 am
    I knew it would be something simple like that. Many thanks.
    Paul
