Activity › Forums › Boris FX Particle Illusion › Particle Viewer not working after removing admin rights
  • Particle Viewer not working after removing admin rights
    Posted by Dean Murray on August 31, 2010 at 9:56 am
    Hi there,
    As I have to use Windows and avoid updates I have removed administrator privileges to limit the impact should I end up “infected” everything appears to work fine except Particle View which opens the window which then turns white and after a few seconds Windows tells me it will close it down.
    If I select “run as” and select my admin account it works fine. Can anybody tell me what permissions should be set and where (files and/or registry) are required to run as a User account?
    I’m running Windows 7 Pro 64 bit.
    Thanks in advance
    Dean
    Dean Murray replied 16 years ago 2 Members · 2 Replies
  • Alan Lorence
    August 31, 2010 at 8:29 pm
    Try deleting your search data. Look for a “wondertouch/search data” folder, which may be in your Documents folder, or possibly in “All Users/Application Data”. Delete that “search data” folder, then try running particleView again.
    Alan.
    http://www.wondertouch.com
  • Dean Murray
    September 6, 2010 at 5:44 pm
    Thanks for the advice.
    I found that under Windows 7 the “search data” folder can be found in C:\ProgramData\wondertouch\
    To get particleView to work again I logged on with an administrator account and gave my user account full control of this folder and files.
    Dean
