Activity Forums Boris FX Particle Illusion Particle View Crashes on Search
  • Particle View Crashes on Search
    Posted by Richard Lyall on January 9, 2009 at 4:13 pm
    Whenever I perform a search in ParticleView, I get the following error, and PV quits.
    “Microsoft Visual C++ Runtime LIbrary
    Runtime Error!
    C:\Art Software\Particle Illusion SE\ParticleView.exe”
    It worked before, but something has obviously changed. Is this a known issue?
    Richard
    Richard Lyall
    https://craftycurate.blogs.com
    Graham Bernard replied 16 years, 9 months ago 3 Members · 3 Replies
  • John Holste
    January 9, 2009 at 8:11 pm
    Richard,
    Make sure you have the latest version 3.2.2. You may need to rebuild the index, delete all files in:
    “C:\Documents and Settings\All Users\Application Data\wondertouch\particleView”
    and
    “C:\Documents and Settings\All Users\Application Data\wondertouch\search data”
    Then rerun particleView, you should get a “building index” window with a progress bar.
    John
  • Richard Lyall
    January 9, 2009 at 9:00 pm
    That’s sorted it, thanks.
    Richard
    Richard Lyall
  • Graham Bernard
    November 20, 2009 at 8:32 am
    Just needed to do this! Thanks John, result.
    Grazie
