Activity › Forums › Adobe After Effects › Particle text that forms and separates
Posted by Wyclef Chron on November 21, 2015 at 12:33 amHello,
Interested in animating some words made up of a custom shaped particle. Wondering if someone could point me in the right direction here?
Here is a pic of something similar to what I am thinking: https://1.bp.blogspot.com/-onnvotiUMf8/TnoFcp0yeKI/AAAAAAAABVk/2hr7xJLhexE/s550/image-2.jpg
Kalleheikki Kannisto replied 10 years, 10 months ago 2 Members · 9 Replies -
Wyclef Chron
November 21, 2015 at 2:43 am -
November 22, 2015 at 9:54 amParticular with a layer emitter for disintegrating and reversed of the same for forming.
Wyclef Chron
November 22, 2015 at 11:36 pmAh, particular seems like the correct direction. Now, when I set a LayerEmit layer on the text comp, it just seems like I’m emitting particles from the text vs. the particles forming the text… what am I missing here? It seems like if I set some keyframes on the direction spread% from 0-some number I can sort of simulate this expanding and contracting motion.
After looking into this some more, I realized what I’m looking to do is a bit different than the standard particle disintegration you see examples of everywhere. I THINK what I want is for there to be no dimension, all the particles are on a flat surface (disc size 5 or something)… there is a set number of particles all the same size that make up the letters (400-500), they expand then contract.
November 23, 2015 at 8:40 amFor forming text you can either use physics time factor or reverse the rendered footage.
(Speaking of “forming”, Trapcode Form is another good tool for this.)
Making it look 2D rather than 3D would primarily be a question of settings. You can limit the Z axis motion to minimum and it will look 2D.
Wyclef Chron
November 23, 2015 at 4:34 pmPlease check these out:
https://reels.creativecow.net/film/24237 (see comment)
9491_particlestest.aep.zip -
Wyclef Chron
November 23, 2015 at 10:07 pmI don’t know guys. Trying this again…
Having a tough time wrangling the particles to behave how I’d like. I guess scrap my previous files… uploaded more current ones. Perhaps part of the problem is that rather than the particles look like it’s making up the text when it expands it just looks like it’s still emitting.
November 24, 2015 at 7:10 amBy reversing I mean literally time reversing the action for the particles coming together. I took your render and used the beginning part, time reversed it for the coming together. (You’d want to ease the motion so it isn’t this rigid.) Particle life is pretty important here. You don’t want to have particles being born and disappearing if you want it to look like they are forming the word.
In that way Form is a better option as the particles are persistent. Also, you can fill the area evenly with less particles in Form.
But it doesn’t look half bad this way either.
Wyclef Chron
November 25, 2015 at 1:48 amYou’re right. That rendering doesn’t look half bad. I think I’ll keep fiddling with it. If I were to switch over to try out Form would it be as straightforward as Particular? Really there should be presets for something like this already… maybe there are somewhere.
November 25, 2015 at 8:18 amI find Form to be a tad easier than Particular. They’re very similar in logic and in terms of controls.
