Activity › Forums › Adobe After Effects › Particle system using a layer as the particle
  • Particle system using a layer as the particle
    Posted by Frank Lima on June 21, 2012 at 9:32 pm
    I do not have ‘Particular’ and I am using CS6. Is there any way that I could generate a particle system using a selected layer as the particle? or the contents within the layer (or pre-comp)
    Walter Soyka replied 14 years, 3 months ago 3 Members · 3 Replies
  • Walter Soyka
    June 21, 2012 at 9:57 pm
    In Particular, change the particle type to one of the “Sprite” or “Textured Polygon” types (the difference is that sprites are always camera-facing, whereas textured polygons can rotate freely about), then select the layer under the Texture option.
    Walter Soyka
  • Dan Fredley
    June 21, 2012 at 10:07 pm
    Use CC Particle World–change the particle type to anything that says “Textured” then under Texture choose the texture layer you want to use.
  • Walter Soyka
    June 21, 2012 at 10:41 pm
    Yikes, sorry — I saw “Particular” but missed the “not.”
    Walter Soyka
