Activity › Forums › Maxon Cinema 4D › Particle System or Cloner Objects
  • Particle System or Cloner Objects
    Posted by Geoff Windosor on March 17, 2015 at 7:17 am
    I’m a veteran of AE but I’m very new at C4D, so apologies about the basic nature of this question. Essentially, I’m trying to re-create this
    https://www.youtube.com/watch?v=q27Jn3h4kpE
    and I’m unsure if I should be trying to set up a particle system via X-Particles/Thinking Particles, or setting up some sort of cloner object array. I’m wanting to keep each of the e coli bodies from intersecting (hard bodies I’m assuming) and was unsure if a particle system would allow per-particle collision detection (which is also why I’m not just using a basic particle system in AE). I was also planning on having to use some sort of turbulence or fractal displacement for the “pathways” the e coli take in their swimming. Basically, since I’m so new to the program I just wanted to get some direction as to where to look to start in my research. I guess in addition to this, is what I’m trying to make really advanced or does this seem manageable? As for the modeling/texturing, I’m planning on straight up using the default capsule shape and doing some flat toon rendering on it. Anyway, thanks in advance for any pointers as to what might be a good approach on it.
    Cheers
    Geoff Windosor replied 11 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 17, 2015 at 8:33 pm
    I’d have to guess (without testing) that a particle system would be the way to go, possibly Flocking with a number of ‘flock leaders’ just following splines maybe. Following a surface probably because that’s what’s happening in the video
  • Geoff Windosor
    March 18, 2015 at 1:02 am
    Good call on the flocking. I wasn’t aware of that and it seems like a good route. Thanks for the pointer!
