Activity Forums Adobe After Effects Particle Project Files
  • Particle Project Files
    Posted by Kevin Dennis on September 19, 2024 at 4:07 pm
    I’m looking for a set or “pack” of AE Particle Project files that can be customized to fit my needs.
    While I’m fairly experienced with AE, I have spent very little time using particle emitters.
    I’m sure I’d be able to tweak the setting if I had a rough start with something close.
    Not sure if I would need CC Particle World or CC Particle Systems II.
    I understand that the main difference is the 3D aspect of Particle World but not sure which I would need to achieve the look I’m after. I figured I would play around with both.
    A retail pack would be fine as well.
    Suggestions? – THANK YOU ALL!
    Kevin Dennis replied 1 year, 11 months ago 3 Members · 7 Replies
  • 7 Replies
    September 19, 2024 at 4:36 pm
    Hey Kevin,
    If you read the small print, BorisFX offers Particle Illusion Pro on a trial that never ends.
    https://vfx.borisfx.com/free-particle-illusion
    They also have some big premade libraries.
    If it does the job, You can buy, or subscribe monthly to a package that works with in AE.
    Otherwise, you could also look at Blender 3D animation.
  • Kevin Dennis
    September 19, 2024 at 4:49 pm
    This is the type of particle effect I’m trying to create.
    https://drive.google.com/drive/folders/105cmM2sIdgyrZSoHxai3wSnYnsM-0n4I?usp=sharing
  • Kevin Dennis
    September 19, 2024 at 4:52 pm
    Thank you Mads – I will definitely look into it.
  • Kevin Dennis
    September 19, 2024 at 5:05 pm
    Hey Mads –
    Do you know if Particle Illusion Pro Trial will allow you to output a video file with an alpha channel?
    Also do you know if there are any resolution restrictions in the trial version?
    Thanks again!
    Kevin
    September 19, 2024 at 5:34 pm
    Hey Kevin,
    I don’t know, sorry. As I already have the full package as part of Continuum.
    But, depending on the shapes that you are flying with, you might be able to pull a key on the background.
    Not sure if the project is portable, but you might be able to do a one month rental when exporting and do it at that point.
    I’m working on PPro today, and there it has both 2D and 3D options + “Particle Illusion” which has presests that are close to your example.
  • John Cuevas
    September 19, 2024 at 7:48 pm
    Kevin, the free version of Particle Illusion will output with an alpha channel.
  • Kevin Dennis
    September 19, 2024 at 8:28 pm
    COOL Thanks!
