Activity Forums Adobe After Effects Particle Playground Rocks my Socks….just need a lil help
  • Particle Playground Rocks my Socks….just need a lil help
    Posted by Ploughman on March 3, 2006 at 9:52 pm
    I desire one of two effects…
    1) Have each particle strobe different colors
    OR
    2) Set a few colors so that each particle comes out as any one of those colors…but stays that color during its entire lifetime
    How would i be able to achieve such effects?
    Ploughman replied 20 years, 6 months ago 2 Members · 2 Replies
  • Adolfo Rozenfeld
    March 4, 2006 at 1:43 am
    Hey, ploughman.
    First of all you need to design the particle layer. As an example, you could create a small solid with the “Circle” effect applied, and animate the circle’s color change over time (animate also Circle raduis if you like). For most cases, you will need to pre-compose that layer (because of AE’s rendering order, so that the Circle particle is “cooked” by the time Particle Playground asks for it).
    Very important: Unlike the layer containing the Particle Playground effect itself, don’t make the particle layer (or pre-composition) at full NTSC or PAL size, but rather make it at just the size needed to contain your particle shape. I hope the wording is clear….
    For the two cases you mention:
    1) In the Layer Map section, set Time Offset Type to “Relative Random”. Set Random Time Max to a suitable time range. Relative random means picking a random frame from your particle layer for each particle, and then animating the cycle for each cell from that random point.
    2) In the Layer Map section, set Time Offset Type to “Absolute Random”. Set Random Time Max to a suitable time range. Absolute random means picking a random frame from your particle layer for each particle, and holding it stil.
    Hope this helps!
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo@adolforozenfeld.com
  • Ploughman
    March 7, 2006 at 7:11 pm
    thank you so much… ive just reached another level of understanding AE… i love this program
