Activity › Forums › Adobe After Effects › particle playground effect – how to implode a layer?
  • particle playground effect – how to implode a layer?
    Posted by Sans.otto on May 13, 2007 at 11:29 am
    Hi guys a need yoor help!:)
    I have to make an implosion with particle!
    i know two differet effect to do this, the trapcode plugin( yes, I posted in the trapcode forum;)), and the particle playground effect.
    i set particle playground like “layer explosion” and it’s work great: the layer explodes in thousands and thousands particles.
    But I want to make the opposite: I want to implode the layer, from thousands particle to no-one, like a reverse-time but not reversed 🙁
    How can I do?
    thanks,
    Andrea
    Sans.otto replied 19 years, 4 months ago 3 Members · 3 Replies
  • Sam Moulton
    May 13, 2007 at 3:08 pm
    make it explode, then pre-compose that and time reverse the pre-comp
  • Michael Zoppo
    May 13, 2007 at 3:23 pm
    Now i dont really stick to pp that much but perhaps if there is a velocity setting or something of the sort you should put it in the negatives, im pretty postive this can be done with particular but im not sure.
  • Sans.otto
    May 13, 2007 at 6:22 pm
    thanks for the tips!
    I’ll try with the pre-comp!
    MikeyforVFX unfortunately I tried to put negative velocity,but nothing..:( probably there is something else to setting that I don’t know
