Activity Forums Adobe After Effects Particle playground and property mapping? Please help.
  • Particle playground and property mapping? Please help.
    Posted by Gizmo1990 on February 8, 2006 at 8:27 pm
    I’m trying to get to grips with AE7’s (tryout version) Particle Playground but I’m having trouble understanding some of its concepts, specifically property mapping/RGB layer maps and how to implement them??
    I’ve checked the help function but it is VERY sparse covering this topic. I don’t understand what RGB maps are supposed to look like and how they effect particles scale, rotations and lifespan, which is what I’m interested in??
    Are the any tutorials people know of that tackle this function (property mapping/RGB layer maps) or could give me a few pointers in this area?
    Any help really appreciated.
    Gizmo1990 replied 20 years, 6 months ago 4 Members · 5 Replies
  • Steve Roberts
    February 8, 2006 at 9:06 pm
    Did you try Googling “particle playground” and “tutorial” together? There should be some tuts there. Roland K did one for the COW.
    The RGB map is an image or movie that you design. The value of a color (e.g. R) at a specific position on the map affects the chosen property (e.g. size) of a particle when it is at that same position.
    So, if you want particles travelling left-to-right across the screen to get bigger as they move, the property map should be an image (or precomped layer) that has a black-to-red linear ramp applied: black on the left, red on the right. As the particle passes through the black zone, it is small, then as the R value increases as it moves to the right, it gets bigger.
    If you want the particles to get bigger then smaller, the ramp should be radial: red in the center, black around the edges. As the particles travel left-to-right, they travel through the black, then red, then black.
    If the particles are static, using a movie as a property map can cause them to change properties based on the colour of the movie in the property map.
    It’s all numerical. When a particle is at position (x,y), it reads the map’s RGB value at that position (x,y) then multiplies the chosen property value by that number, with or without another factor you set.
    Recall that white has high values for R, G and B.
    You must precompose a layer that has had an effect applied if you want to use it as a layer map.
    Particle Playground particles do not exist in 3D space.
    A layer map can be a movie.
    To make a grid, set the cannon velocity to 0.
    As for the persistent and ephemeral stuff, I’d have to check the manual for that.
    Does that help?
  • Roland R. kahlenberg
    February 9, 2006 at 2:53 am
    The Fun in Particle Playground tutorial is missing.
    That one covers the creation of property mappers.
    Cheers
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Kathlyn Lindeboom
    February 9, 2006 at 6:36 pm
    Thanks for the heads up. It probably dropped it’s metas — I’ll see if I can find it and fix it.
    Kathlyn Lindeboom
    The Mistress of Mmmooooo!
  • Kathlyn Lindeboom
    February 9, 2006 at 6:51 pm
    Thanks for letting me know it was “missing.” — Of course, it was still there. Sometimes the metas get lost and we have to go find them and help them home. Maybe too much drinking or something. :-0
    You can find it by clicking on the After Effects COW title banner or click here to go directly to it.
    Couldn’t pass up the dancing cow.
    Kathlyn Lindeboom
  • Gizmo1990
    February 10, 2006 at 12:29 pm
    Thanks for all the help guys. I’m finally beginning to find my feet with particles.
    Thanks especially to Steve Roberts for taking the time the explain some of the processes involved. 🙂
