Activity › Forums › Adobe After Effects › Particle Playground
  • Particle Playground
    Posted by Jon Henry on June 17, 2010 at 5:13 pm
    Hi everyone!
    I have used particle playground to generate a bunch of confetti in a still photo. My problem is, I want the effect to move in slow motion, but I want all the confetti to follow the same path its following right now. I can’t seem to slow down the movement, aside from precomposing the comp and time remapping, but that looks stuttery.
    Any ideas?
    Jon Henry replied 16 years, 3 months ago 2 Members · 2 Replies
  • Brian Charles
    June 17, 2010 at 5:56 pm
    Have you tried the Persistent Property Mapper? You can use a gradient to control the speed in either X or Y.
  • Jon Henry
    June 17, 2010 at 8:01 pm
    Thanks, Brian, that does look like one way of achieving the effect that I wanted.
    What I ended up doing was changing the comp frame rate to 99fps, exporting a tiff sequence that i import at 24fps. Made the effect look like nice slick slow motion.
    Cheers
