Activity Forums VEGAS Pro Particle Illusion Problem
  • Joao Souza
    February 25, 2015 at 6:40 pm
    Looks like crap the same way.
    I gotta find out why when I try to save to AVI, I can’t select save alpha, why are all settings locked?
    I just find out if I try to import an avi video,PI crashes…………….always.
    We have so much time and so little to do! / Willy Wonka
  • Joao Souza
    February 25, 2015 at 6:42 pm
    What software?
    I don’t understand your question, I create smoke with PI then open it in Vegas.
  • Graham Bernard
    February 26, 2015 at 11:27 am
    [Joao Souza] “I gotta find out why when I try to save to AVI, I can’t select save alpha, why are all settings locked?”
    Hmmm…
    Here are all my AVI options and therefore my Settings for AVI are live:-
    You have NO live AVI options?
    G
  • Joao Souza
    February 26, 2015 at 1:00 pm
    My PI is different than yours(mine is 3.0), that save output box has only settings for file output, codec options are in the second box, only with avi options are locked, I can’t check save alpha channel box.
    Here1s save output box, all settings are blocked, I click ok then a second box let me choose a codec but still I couldn’t check save alpha box.
  • Graham Bernard
    February 26, 2015 at 1:20 pm
    [Joao Souza] “I can’t check save alpha channel box.”
    I just ignore that and click OK. Then I get the CODEC stuff.
    My PI is 3.09.
    G
  • Joao Souza
    February 26, 2015 at 1:26 pm
    So you don’t know why save alpha box is locked or how I could unlock it?
  • Graham Bernard
    February 26, 2015 at 2:16 pm
    If you’re asking, then my best guess would be that you need to go to the next Screen select the AVI that allows for ALPHA, which works for me, and then, as I’ve experienced, click the save ALPHA.
    G
  • Joao Souza
    February 26, 2015 at 2:20 pm
    I already said more than 3 times that options are locked no matter whatever codec I choose.
    Codecs are in the second box so once I chose a codec, I can’t return to the 1st box.
    A friend of mine jus brought me PI 3.04.
    It looks like yours and……………..when I click RENDER it says = Could not find an acceptable pixel format!
    What the hell does that mean?
    LOL
  • Graham Bernard
    February 26, 2015 at 2:28 pm
    Do you think you need to reinstall Particle Illusion? Sounds like parts of the program aren’t aware of what you’ve installed. Have you got the latest version to install?
    What do you think?
    Grazie
  • Joao Souza
    February 26, 2015 at 2:39 pm
    “A friend of mine jus brought me PI 3.04.
    LOL”
    I found the problem, when I click render it asks if stage should be 100%, I have to set NO then it works.
    Graham thanks for your patience 😉
Page 2 of 3
