Activity Forums Boris FX Particle Illusion, Primatte, Title Studio for Apple
  • Particle Illusion, Primatte, Title Studio for Apple
    Posted by Marcus Warren on June 13, 2019 at 9:09 pm
    I did a search on this topic but did not find anything, so forgive me if this has been covered, but when will Particle Illusion, Primatte and Title Studio be available for Continuum/Apple, or will they ever be collectively or individually available?
    We have been waiting a long time…
    I hope this is not like Boris RED 6; promised for years and never appeared. If they are not coming for Apple FCPX/Motion, just say so.
    Thanks for your time.
    Kirk Pitts replied 7 years, 2 months ago 2 Members · 2 Replies
  • Kirk Pitts
    June 20, 2019 at 1:56 pm
    I was told a few years ago in a support email that it was because of limitations with Apple’s plug in architecture. Also the reason they said that 3D objects were removed. The rep told me to switch to Adobe. Ha! No intention to join the subscription chain. Moved on to Coremelt and others. Still use what I have but don’t plan to update again until they add those features. Which I don’t expect them to ever add to FCPX version.
    Hopefully, one day they will prove me wrong.
    Kirk Pitts.
    video amateur.
    Personal skateboard and band historian. 😉
  • Kirk Pitts
    June 20, 2019 at 10:23 pm
    New version update notes for apple.
    Continuum 2019.5 (v12.5.0) for Apple Final Cut Pro / FxPlug – Release Notes
    What’s New in Continuum 2019.5 for OFX (Summary of major changes since Continuum 2019.0):
    Spill Remover – New Filter
    Spill Remover is a new simple and robust way to remove spill from your key along with a new light wrap approach based on the spill map.
    Light Wrap from Solid Color
    Light Wrap (in all filters where it occurs) has a new option to take the light wrap colors from a Solid Color instead of from a background layer which is a handy shortcut for simple scenes.
    Final Cut Text Templates
    Updated Text templates
    Continuum 2019.5.0 (internal version 12.5.0) (BCC 2019.5.0 v12.5.0) for FxPlug was released on 6/12/2019.
    Continuum 2019.5.0 (v12.5.0) for Apple FxPlug officially supports the following host applications:
    macOS 10.11, 10.12, 10.13, 10.14 (as appropriate for the host version in use):
    Final Cut Pro X 10.2, 10.3, and 10.4 Motion 5.2, 5.3, and 5.4
    Training:
    Numerous resources are available for helping you get the most out of Boris Continuum Complete.
    Help documents for individual BCC effects are accessible directly from each plug-in’s UI. The entire BCC Help Documention library is also available on the BorisFX website, including access to a downloadable version for browsing Offline BCC Help Documentation.
    BorisTV video tutorials cover a huge range of topics including introductions to the fundamentals, deep training webinar replays, and in-depth looks at key effects and techniques.
    Continuum 2019.5.0 (v12.5.0) for FxPlug Compatibility Notes:
    While in general your previously saved projects should render identically in the newer version, bug fixes and quality improvements can sometimes change the look of older projects. While every effort is made to ensure project compatibility, the following notable areas may see some change to the look of previously saved projects.
    None known
    Kirk Pitts.
    video amateur.
