Activity › Forums › Boris FX Particle Illusion › Particle Illusion in After effects 7 ?
  • Particle Illusion in After effects 7 ?
    Posted by Rafael750 on February 13, 2006 at 7:53 pm
    Particle Illusion don’t work with After Effects 7 ?????
    When I import clipboard, i see error message !
    I try copy clipboard (position frame) to “tab-delimited Text (from file)” but position not correspond in after effects 7 ,,
    Do you have some secret to this ? I use Windows XP !
    Rafael750@yahoo.com.br
    Brasilia-Brazil
    Alan Lorence replied 20 years, 7 months ago 3 Members · 4 Replies
  • Alan Lorence
    February 13, 2006 at 9:41 pm
    There was a slight change in the data format from AE 6.5 to AE 7.0. I suggest copying the data to a text file, then deleting every line except the lines that contain the position data. Each line should be in the format:
    Frame_number X_pos Y_pos
    Then you should be able to load it into pI3.
    Alan.
    wondertouch
  • Rafael750
    February 13, 2006 at 11:17 pm
    Oh thanks !
  • Jeff Bellune
    February 14, 2006 at 3:35 am
    Hi Alan,
    I know you are working on the plug-in for AE and I have read a few topics here in the forum about that plug-in. I have 2 questions:
    1. Will the plug-in for AE, when released, be compatible with AE7?
    2. Will there be an update to the pI stand-alone version 3 that will properly import keyframe information from AE7 via the clipboard?
    -Jeff
  • Alan Lorence
    February 14, 2006 at 1:16 pm
    Yes to both.
    Alan.
    wondertouch
