Activity › Forums › Boris FX Particle Illusion › Particle Illusion Hangs after update to 3.0.8 (Mac OS X)
  • Particle Illusion Hangs after update to 3.0.8 (Mac OS X)
    Posted by Albert Kiefer on January 6, 2009 at 9:37 am
    Yesterday I updated my Particle Illusion to the latest 3.0.8 on Mac OS X. I validated via the online page and after that Particle Illusion crashed. I restarted the application and it then wants me to point it to an emitter library. However the startup screen stays open and whatever I do I cannot actually select a librarie via the file browser so the app stays waiting forever and I can’t start working.
    Is there a way to reset the whole application? Or does anybody know what I should do to fix this?
    Thanks in advance,
    Albert Kiefer
    Alan Lorence replied 16 years, 8 months ago 3 Members · 4 Replies
  • Alan Lorence
    January 6, 2009 at 12:11 pm
    Delete your preferences file:
    / Library / Preferences / pIllusion3.prefs
    That should fix it.
    Alan.
    http://www.wondertouch.com
  • Stan Miskiewicz
    January 21, 2010 at 1:40 am
    There are PI files in the Prefs folder!?
    I deleted PI and did a new install
    same thing
    starts to open
    hangs
    looking for emitter library
    in a folder called MacOS
    which I can not find
    thanks
  • Stan Miskiewicz
    January 21, 2010 at 2:21 am
    Well for me it was because I unpluged my mac from the server network I have.
    when I plugged the mac back into the router it worked…..????
    it works thats all I want
    Stan
  • Alan Lorence
    January 21, 2010 at 1:56 pm
    It’s probably stuck trying to look for updates. It should know that there is no Internet connection available, but it may be that the timeout period is too long.
    It may also be related to the problem where it won’t see any updates or emitter libraries available on OS X (Snow Leopard only?).
    You should turn off the “check for updates” option in the preferences if you’re not going to keep it connected to the Internet.
    Alan.
