Activity Forums Boris FX Particle Illusion particle illusion for after effects Problem !!
  • particle illusion for after effects Problem !!
    Posted by Mark Michael on February 26, 2011 at 9:28 pm
    i got the plugin called partilce illusion for after effects CS4 …it’s job is to allow you to import particle illusion (vfx software) emmiters in after effects…….
    i have everything set up correctly but when i go into add an effect nothing happens. I lay a video down. go to effect>wondertouch>particle illusion, go through the menu and select my effect (and also the emitter doesn’t appear properly in the preview window) then back to the video and nothing shows up…am i doing something wrong?
    BY the way i have the partilce illusion software and it works prfectly !!
    plz help….thx in response
    Christian Larocque replied 11 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Alan Lorence
    February 28, 2011 at 2:34 pm
    You need to buy the plug-in too. It’s a separate product.
    Alan.
    http://www.wondertouch.com
  • Mark Michael
    March 2, 2011 at 9:18 pm
    did so !!
  • Beth Hunter
    March 11, 2011 at 4:56 am
    I’m having exactly the same problem.
    AE CS4 on Windows 7
    The plugin doesn’t display anything either in the preview window or after adding it as an effect.
    I have PI3 and the AE plugin. Both are bought, paid for and activated. PI3 works, the plugin doesn’t.
  • Alan Lorence
    March 11, 2011 at 12:20 pm
    OpenGL problems.
    1) Make sure AE isn’t using OpenGL for “fast previews” or rendering. “Fast previews” is the little lightning bolt icon under the comp window, and rendering is set in prefs I believe.
    2) Download the latest drivers for your graphics card from the card manufacturer’s website, or directly from NVIDIA if you have an NVIDIA-based card.
    Alan.
  • Scott Novasic
    April 23, 2011 at 9:20 pm
    but Alan… if someone has Pi 3 AND it works fine with the video card they have… shouldnt the AE plug also be ok then?
    im not trying to cause any trouble… but im also looking to buy the Mac plug in so im checking out how people are feeling about it…
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    https://supernovavfx.com
  • Alan Lorence
    April 25, 2011 at 2:41 pm
    No, because as a standalone application pI3 has control over everything. As a plug-in, AE is in control.
    Alan.
  • Christian Larocque
    May 10, 2015 at 2:48 am
    I am having a problem to with Particle Illusion for AE
    Why cant I see the Emitter Libraries in a window. Only one Emitter.. (Star Trail) appears with no problem in the effects control panel. But I have no access to the basic libraries that I install.
    I have PI install as a standalone and works fine.
    Working on Window 7 / 64 bits and AE CS6 / CC 2014
    PI / installed 1.042
    Need help please
