Activity › Forums › Boris FX Particle Illusion › particle illusion and flash MX
Posted by Sean on May 11, 2005 at 6:12 pmis it possible to use particle illusion with flash?
Mike Clasby replied 21 years, 4 months ago 3 Members · 4 Replies -
Mike Clasby
May 12, 2005 at 12:50 amGo ask at the particle Illusion forum:
https://www.creativecow.net/forum/view_posts.php?forumid=23
I’ve just started playing with it, and it produces AVI’s or targa sequences. Rumor from the founder has an After Effects PI plugin coming out soon. Since AE outputs swfs (although rather fat jpegs for raster stuff) you can output PI effects as swfs in the future.
Mike Clasby
May 12, 2005 at 12:56 amMy mistake about sending you to the PI forum, I though I was still on the Cow AE forum, allniters for us old folks are deadly.
Here’s a Q for the PI founder since he’ll probably see this:
Can the AE PI plugin use Illustrator files (as imported layers in AE) for particles. If so, since AE makes sall swfs from AI shapes, maybe AE will output vector particle creations. Hmmm. The thought is mind boggling. Probably too good to be true.
Alan Lorence
May 12, 2005 at 2:41 amIn theory you should be able to use any AE layer as the source (particle shape image) for a particle, although we haven’t tested this since it’s not working yet.
I’m pretty sure that there will be a vector-to-raster conversion in there though, so the output won’t be vector (I think).
Alan.
wondertouch -
Mike Clasby
May 12, 2005 at 6:53 amThanks for the reply. Yeah, almost all effects are rasterized on output to Swf, except Audio Waveform and Audio Spectrum and Path Text.I’m looking forward to the PI AE fit. Thanks for keeping after it.
