Activity Forums Boris FX Particle Illusion Particle Illusion and after effects
  • Particle Illusion and after effects
    Posted by Katsoft on March 31, 2006 at 10:21 am
    Hello I have a problem…..I use Particle Illusion 3.0 and Adobe After Effects 7.0 and when I try to import position data from AE7 in PI3 I get this error message : ” No valid clipboard data ” …..and I made everything as I suposed to do I copyed the postion of something …just that PI3 doesn’t let me import the data. Can anyone tell me why?
    Thank You for your time.
    Yono Yo replied 16 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Alan Lorence
    March 31, 2006 at 8:08 pm
    The data format changed slightly in AE 7. I think there is a workaround that requires an additional step.
    Can you paste the AE 7 data here so I can look at it?
    Alan.
    wondertouch
  • Alan Lorence
    March 31, 2006 at 8:26 pm
    Ok, here’s what you need to do.
    1) Copy the keys to the clipboard in AE as usual
    2) open Notepad (or some other text editor) and paste
    3) Find the line that starts with “Transform”. Delete “Transform” and the spaces so the line now starts with “Position”.
    4) Select all of the text and Copy it to the clipboard.
    5) Import into pI3 as usual.
    Note that you only need to do this in pI3 for Windows. pI3 for Mac can already handle the AE 7 data.
    Alan.
    wondertouch
  • Katsoft
    March 31, 2006 at 11:44 pm
    Thank you very much for your help.
    Catalin.
  • Philippe Bouyer
    April 19, 2006 at 11:16 am
    Just have the same issue. Thanks both for that thread! That’s help! :-)))
    Philippe Bouyer (Paris)
    http://www.belino.net
  • Yono Yo
    March 22, 2010 at 6:32 pm
    Same problem concerning coords import from AE CS4 to particle illusion 3.0.1.
    It works using your textedit copy/paste trick and deleting the “transform” part, but particle illusion misinterprets it.
    Anyone can help ?
  • Alan Lorence
    March 22, 2010 at 7:06 pm
    Update to the latest version of particleIllusion 3. Version 3.0.1 may contain a bug in that area. It’s been so long I can’t remember.
    Alan.
    http://www.wondertouch.com
  • Yono Yo
    March 22, 2010 at 8:08 pm
    I’ll try to upgrade (I thought I was already up to date !).
    Thank you very much for responding so quickly !
