Activity Forums Boris FX Particle Illusion Particle Illusion After Effects CRASH upon render
  • Particle Illusion After Effects CRASH upon render
    Posted by Joe Ferralli on April 21, 2010 at 1:57 pm
    Hi, I’m running PI for AE v1.0 on a Vista 64 PC in CS4. Every time I try to render, I get a blank error box that comes up and totally freezes AE. Any ideas on how to fix?
    Joe
    Alan Lorence replied 16 years, 5 months ago 2 Members · 1 Reply
  • Alan Lorence
    April 21, 2010 at 2:31 pm
    Does the error box have text in the title bar? Is there anything in the error box at all?
    Does this happen with any emitter you load, or only certain ones?
    Do you have any other effects applied, or is pIAE the only one?
    Is it applied to footage, a solid, or adjustment layer?
    Try a simple comp with a solid and only pIAE applied and see if the same thing happens. If it does, then close AE and check if your graphics card has updated video drivers — go to your card manufacturer’s website, which may be ATI, NVIDIA, or others.
    Alan.
    http://www.wondertouch.com
